홈/ 질문/Q 102044
등록일: 2014-08-302014-08-30T10:59:57+09:00 2014-08-30T10:59:57+09:00카테고리: AutoCAD & CADian
lisp을 작성 했는데… 인수가 너무 많다고 뜨네요
회사 업무상 자동으로 만드려고 lisp을 만드는데
인수가 많다고 떠서요…
(defun c:gg(/ dcl_id tg1 tg2 tg3 tg4 tg5 tg6 ky fn fname)
(vl-load-com)
(create_dialog_ad)
(prompt “n** 도면 정리 하기 **nn”)
(setq dcl_id (load_dialog fname))
(setq ky 4 tg1 “1” tg2 “1” tg3 “1” tg4 “1” tg5 “0” tg6 “0”)
(if (not (new_dialog “temp” dcl_id)) (exit) );if
   (set_tile “tog1” tg1)
   (set_tile “tog2” tg2)
   (set_tile “tog3” tg3)
   (set_tile “tog4” tg4)
   (set_tile “tog5” tg5)
   (set_tile “tog6” tg6)
   (action_tile “tog1” “(setq tg1 $value)”)
   (action_tile “tog2” “(setq tg2 $value)”)
   (action_tile “tog3” “(setq tg3 $value)”)
   (action_tile “tog4” “(setq tg4 $value)”)
   (action_tile “tog5” “(setq tg5 $value)”)
   (action_tile “tog6” “(setq tg6 $value)(@ff_select tg6)”)
   (action_tile “accept” “(setq ky 9)(done_dialog)”)
   (action_tile “cancel” “(done_dialog)”)
  (start_dialog)
  (unload_dialog dcl_id)
  (if (= ky 9)(progn
  (command “undo” “be”)
  (if (=tg1 “1”) (@KI))
  (if (=tg2 “1”) (@TSE))
  (if (=tg3 “1”) (@JEM))
  (if (=tg4 “1”) (@MF))
  (if (=tg5 “1”) (@AMST))
  (command “undo” “e”)
  (prompt “nn** 작업완료 **”))
    (vl-file-delete fname)
;;subroutine (서브루틴)
(defun @ff_selecl(tg6)
  (cond
      ((= tg6 “0”)(setq tg1 “0” tg2 “0” tg3 “0” tg4 “0” tg5 “0”))
      ((= tg6 “1”)(setq tg1 “1” tg2 “1” tg3 “1” tg4 “1” tg5 “1”))
   (set_tile “tog1” tg1)(set_tile “tog2” tg2)
   (set_tile “tog3” tg3)(set_tile “tog4” tg4)
   (set_tile “tog5” tg5)(set_tile “tog6” tg6)
;;KI 가공도면 제작
(defun @KI(/ss ss1)
;   (prompt “n ** 가공도면 **nn”)
  (setq $cmdecho (getvar “CMDECHO”))
  (setvar “CMDECHO” 0)
  (setq $osmode (getvar “OSMODE”))
  (setvar “OSMODE” 0)
  (command “ERASE” “win” (list 450 240)
       (list -348 203)
      (list 450 240)
       (list 411.62 -329.39)
    (list 450 -315)
       (list -329.31 -197.28)
      (list -291.62 -338.32)
       (list -326 240)
    (list 83.15 -48.35)
       (list 168.87 -54.94)
    (list 32.01 -62.14)
       (list 18.40 -77.50)
    (list -134.6919 123.03)
       (list -28.26 36.84)
      (list 30.59 122.22)
       (list 138.63 36.03)
      (list 33.822 -34.84)
       (list 128.96 -133.12)
      (list -132.27 -40.48)
       (list -33.09 -129.89)
      (list 181.4325 168.14)
       (list 439 91.61)
      (list 216 1.3)
       (list 421.66 -208.23)
      (list -233.4 67.4)
       (list -147.56 -32.69)
  (prompt “ncolor select move..”)
  (setq tt (GETINT “n색상입력: “))
  (if (setq ss (ssget (list (cons 62 tt))))
  (command “ERASE” ss “”)
  (command “zoom” “.7x”)
  (command “regen”)
  (setvar “OSMODE” $osmode)
  (setvar “CMDECHO” $cmdecho)
;; —————————————————— dcl start —————————–
(defun create_dialog_ad ()
(setq fname (vl-filename-mktemp “purge_temp.dcl”))
(setq fn (open fname “w”))
(write-line “temp
: dialog { label=”고객사별 가공도면”;
   : boxed_column {
   label = ”고객사 선택”;
        : column {
            : toggle {
                   label=” KI”;
                   key=”tog1”;
            : toggle {
                   label=” TSE”;
                   key=”tog2”;
            : toggle {
                   label=”JEM”;
                   key=”tog3”;
            : toggle {
                   label=” MF”;
                   key=”tog4”;
            : toggle {
                   label=” AMST”;
                   key=”tog5”;
           : toggle {
                   label=” 모두 선택하기(&Select) / 모두 취소하기”;
                   key=”tog6”;
   ok_cancel;}
” fn)
(close fn)
);defun
;; —————————————————— dcl end —————————–
제가 만든 리습인데…
아직 다 만들지 않았지만..
command 뒤에 ERAES 부분에 인수가 많다고 뜨는거 같은데..
lisp 고수님들 원인 확인좀 부탁드리겠습니다 ㅠ
  • 95 조회
