홈/ 질문/Q 96169
코피칠갑
코피칠갑Lv.0
등록일: 2012-09-172012-09-17T08:55:37+09:00 2012-09-17T08:55:37+09:00카테고리: AutoCAD & CADian
trim 명령어가 먹히질 않습니다.
tr 명령어를 치면 text name 이라고 뜨면서 trim 실행이 안되는군요.
acad.pgp 파일에 보면
TR,        *TRIM
이렇게 되어있거든요.
뭐가 문제인지 아시는분 답변 부탁드립니다.
  • 71 조회
      2012-09-17T21:24:22+09:00답변 등록 답변 등록 일시 2012-09-17 9:24 pm
      3A,        *3DARRAY
      3DMIRROR,  *MIRROR3D
      3DNavigate,*3DWALK
      3DO,       *3DORBIT
      3DW,       *3DWALK
      3F,        *3DFACE
      3M,        *3DMOVE
      3P,        *3DPOLY
      3R,        *3DROTATE
      A,         *ARC
      AC,        *BACTION
      ADC,       *ADCENTER
      AECTOACAD, *-ExportToAutoCAD
      AA,        *AREA
      AL,        *ALIGN
      3AL,       *3DALIGN
      AP,        *APPLOAD
      AR,        *ARRAY
      -AR,       *-ARRAY
      ATI,       *ATTIPEDIT
      ATT,       *ATTDEF
      -ATT,      *-ATTDEF
      ATE,       *ATTEDIT
      -ATE,      *-ATTEDIT
      ATTE,      *-ATTEDIT
      B,         *BLOCK
      -B,        *-BLOCK
      BC,        *BCLOSE
      BE,        *BEDIT
      BH,        *HATCH
      BO,        *BOUNDARY
      -BO,       *-BOUNDARY
      BR,        *BREAK
      BS,        *BSAVE
      BVS,       *BVSTATE
      C,         *CIRCLE
      CAM,       *CAMERA
      CH,        *PROPERTIES
      -CH,       *CHANGE
      CHA,       *CHAMFER
      CHK,       *CHECKSTANDARDS
      CLI,       *COMMANDLINE
      COL,       *COLOR
      COLOUR,    *COLOR
      CO,        *COPY
      CP,        *COPY
      CT,        *CTABLESTYLE
      CYL,       *CYLINDER
      D,         *DIMSTYLE
      DAL,       *DIMALIGNED
      DAN,       *DIMANGULAR
      DAR,       *DIMARC
      JOG,       *DIMJOGGED
      DBA,       *DIMBASELINE
      DBC,       *DBCONNECT
      DC,        *ADCENTER
      DCE,       *DIMCENTER
      DCENTER,   *ADCENTER
      DCO,       *DIMCONTINUE
      DDA,       *DIMDISASSOCIATE
      DDI,       *DIMDIAMETER
      DED,       *DIMEDIT
      DI,        *DIST
      DIV,       *DIVIDE
      DJL,       *DIMJOGLINE
      DJO,       *DIMJOGGED
      DL,        *DATALINK
      DLI,       *DIMLINEAR
      DLU,       *DATALINKUPDATE
      DO,        *DONUT
      DOR,       *DIMORDINATE
      DOV,       *DIMOVERRIDE
      DR,        *DRAWORDER
      DRA,       *DIMRADIUS
      DRE,       *DIMREASSOCIATE
      DRM,       *DRAWINGRECOVERY
      DS,        *DSETTINGS
      DST,       *DIMSTYLE
      DT,        *TEXT
      DV,        *DVIEW
      DX,        *DATAEXTRACTION
      E,         *ERASE
      ED,        *DDEDIT
      EL,        *ELLIPSE
      ER,        *EXTERNALREFERENCES
      EX,        *EXTEND
      EXIT,      *QUIT
      EXP,       *EXPORT
      EXT,       *EXTRUDE
      F,         *FILLET
      FI,        *FILTER
      FREEPOINT, *POINTLIGHT
      FSHOT,     *FLATSHOT
      G,         *GROUP
      -G,        *-GROUP
      GD,        *GRADIENT
      GEO,       *GEOGRAPHICLOCATION
      GR,        *DDGRIPS
      H,         *HATCH
      -H,        *-HATCH
      HE,        *HATCHEDIT
      HI,        *HIDE
      I,         *INSERT
      -I,        *-INSERT
      IAD,       *IMAGEADJUST
      IAT,       *IMAGEATTACH
      ICL,       *IMAGECLIP
      IM,        *IMAGE
      -IM,       *-IMAGE
      IMP,       *IMPORT
      IN,        *INTERSECT
      INF,       *INTERFERE
      IO,        *INSERTOBJ
      J,         *JOIN
      L,         *LINE
      LA,        *LAYER
      -LA,       *-LAYER
      LAS,       *LAYERSTATE
      LE,        *QLEADER
      LEN,       *LENGTHEN
      LI,        *LIST
      LINEWEIGHT, *LWEIGHT
      LMAN,      *LAYERSTATE
      LO,        *-LAYOUT
      LS,        *LIST
      LT,        *LINETYPE
      -LT,       *-LINETYPE
      LTYPE,     *LINETYPE
      -LTYPE,    *-LINETYPE
      LTS,       *LTSCALE
      LW,        *LWEIGHT
      M,         *MOVE
      MA,        *MATCHPROP
      MAT,       *MATERIALS
      ME,        *MEASURE
      MI,        *MIRROR
      ML,        *MLINE
      MLA,       *MLEADERALIGN
      MLC,       *MLEADERCOLLECT
      MLD,       *MLEADER
      MLE,       *MLEADEREDIT
      MLS,    *MLEADERSTYLE
      MO,        *PROPERTIES
      MS,        *MSPACE
      MSM,       *MARKUP
      MT,        *MTEXT
      MV,        *MVIEW
      NORTH,     *GEOGRAPHICLOCATION
      NORTHDIR,  *GEOGRAPHICLOCATION
      O,         *OFFSET
      OP,        *OPTIONS
      ORBIT,     *3DORBIT
      OS,        *OSNAP
      -OS,       *-OSNAP
      P,         *PAN
      -P,        *-PAN
      PA,        *PASTESPEC
      PARAM,     *BPARAMETER
      PARTIALOPEN, *-PARTIALOPEN
      PE,        *PEDIT
      PL,        *PLINE
      PO,        *POINT
      POL,       *POLYGON
      PR,        *PROPERTIES
      PRCLOSE,   *PROPERTIESCLOSE
      PROPS,     *PROPERTIES
      PRE,       *PREVIEW
      PRINT,     *PLOT
      PS,        *PSPACE
      PSOLID,    *POLYSOLID
      PTW,       *PUBLISHTOWEB
      PU,        *PURGE
      -PU,       *-PURGE
      PYR,       *PYRAMID
      QC,        *QUICKCALC
      QCUI,      *QUICKCUI
      R,         *REDRAW
      RA,        *REDRAWALL
      RC,        *RENDERCROP
      RE,        *REGEN
      REA,       *REGENALL
      REC,       *RECTANG
      REG,       *REGION
      REN,       *RENAME
      -REN,      *-RENAME
      REV,       *REVOLVE
      RO,        *ROTATE
      RP,        *RENDERPRESETS
      RPR,       *RPREF
      RR,        *RENDER
      RW,        *RENDERWIN
      S,         *STRETCH
      SC,        *SCALE
      SCR,       *SCRIPT
      SE,        *DSETTINGS
      SEC,       *SECTION
      SET,       *SETVAR
      SHA,       *SHADEMODE
      SL,        *SLICE
      SN,        *SNAP
      SO,        *SOLID
      SP,        *SPELL
      SPL,       *SPLINE
      SPLANE,    *SECTIONPLANE
      SPE,       *SPLINEDIT
      SSM,       *SHEETSET
      ST,        *STYLE
      STA,       *STANDARDS
      SU,        *SUBTRACT
      T,         *MTEXT
      -T,        *-MTEXT
      TA,        *TABLET
      TB,        *TABLE
      TH,        *THICKNESS
      TI,        *TILEMODE
      TO,        *TOOLBAR
      TOL,       *TOLERANCE
      TOR,       *TORUS
      TP,        *TOOLPALETTES
      TR,        *TRIM
      TS,        *TABLESTYLE
      UC,        *UCSMAN
      UN,        *UNITS
      -UN,       *-UNITS
      UNI,       *UNION
      V,         *VIEW
      -V,        *-VIEW
      VP,        *DDVPOINT
      -VP,       *VPOINT
      VS,    *VSCURRENT
      VSM,       *VISUALSTYLES
      -VSM,      *-VISUALSTYLES
      W,         *WBLOCK
      -W,        *-WBLOCK
      WE,        *WEDGE
      X,         *EXPLODE
      XA,        *XATTACH
      XB,        *XBIND
      -XB,       *-XBIND
      XC,        *XCLIP
      XL,        *XLINE
      XR,        *XREF
      -XR,       *-XREF
      Z,         *ZOOM
      ; The following are alternative aliases and aliases as supplied
      ;  in AutoCAD Release 13.
      AV,        *DSVIEWER
      CP,        *COPY
      DIMALI,    *DIMALIGNED
      DIMANG,    *DIMANGULAR
      DIMBASE,   *DIMBASELINE
      DIMCONT,   *DIMCONTINUE
      DIMDIA,    *DIMDIAMETER
      DIMED,     *DIMEDIT
      DIMTED,    *DIMTEDIT
      DIMLIN,    *DIMLINEAR
      DIMORD,    *DIMORDINATE
      DIMRAD,    *DIMRADIUS
      DIMSTY,    *DIMSTYLE
      DIMOVER,   *DIMOVERRIDE
      LEAD,      *LEADER
      TM,        *TILEMODE
      ; Aliases for Hyperlink/URL Release 14 compatibility
      SAVEURL, *SAVE
      OPENURL,   *OPEN
      INSERTURL, *INSERT
      ; Aliases for commands discontinued in AutoCAD 2000:
      AAD,        *DBCONNECT
      AEX,        *DBCONNECT
      ALI,        *DBCONNECT
      ASQ,        *DBCONNECT
      ARO,        *DBCONNECT
      ASE,        *DBCONNECT
      DDATTDEF,   *ATTDEF
      DDATTEXT,   *ATTEXT
      DDCHPROP,   *PROPERTIES
      DDCOLOR,    *COLOR
      DDLMODES,   *LAYER
      DDLTYPE,    *LINETYPE
      DDMODIFY,   *PROPERTIES
      DDOSNAP,    *OSNAP
      DDUCS,      *UCS
      ; Aliases for commands discontinued in AutoCAD 2004:
      ACADBLOCKDIALOG,  *BLOCK
      ACADWBLOCKDIALOG, *WBLOCK
      ADCENTER,         *ADCENTER
      BMAKE,            *BLOCK
      BMOD,             *BLOCK
      BPOLY,            *BOUNDARY
      CONTENT,          *ADCENTER
      DDATTE,           *ATTEDIT
      DDIM,             *DIMSTYLE
      DDINSERT,         *INSERT
      DDPLOTSTAMP,      *PLOTSTAMP
      DDRMODES,         *DSETTINGS
      DDSTYLE,          *STYLE
      DDUCS,            *UCSMAN
      DDUCSP,           *UCSMAN
      DDUNITS,          *UNITS
      DDVIEW,           *VIEW
      DIMHORIZONTAL,    *DIMLINEAR
      DIMROTATED,       *DIMLINEAR
      DIMVERTICAL,      *DIMLINEAR
      DOUGHNUT,         *DONUT
      DTEXT,            *TEXT
      DWFOUT,           *PLOT
      DXFIN,            *OPEN
      DXFOUT,           *SAVEAS
      PAINTER,          *MATCHPROP
      PREFERENCES,      *OPTIONS
      RECTANGLE,        *RECTANG
      SHADE,            *SHADEMODE
      VIEWPORTS,        *VPORTS
      2012-09-17T13:55:48+09:00답변 등록 답변 등록 일시 2012-09-17 1:55 pm
      text name 명령어가 일반명령어인지 리습명령어인지 모르겠지만
      아마 명령중복인것 같습니다
      매개변수편집이나  리습명령편집창을 확인해보세요
