홈/ 질문/Q 105202
등록일: 2015-10-082015-10-08T14:31:16+09:00 2015-10-08T14:31:16+09:00카테고리: AutoCAD & CADian
ucs관련 블럭리습
ucs값이 들어가있는 도면에 블럭을 좌표값에 맞게 넣으려고 리습을 짰는데 먹히지가 않아요;;;왕초보라 이것저것 짜집기해서 한번만봐주세요
(defun c:bbre()
  (GRAPHSCR)
  (setq ata (getvar “attdia”))
  (setq cdo (getvar “cmdecho”))
  (setvar “attdia” 0)
  (setvar “cmdecho” 0)
        (command “layer” “m” “remark” “”)
        (command “layer” “s” “remark” “”)
        (if (/= (setq s1 (ssget “x” (list (cons 0  “INSERT”)(cons 2 “BO”)))) nil)
        (setq es (ssname s1 0))
        );exit if
       (command “UCS” “E” s1)
        (search)
        (command “insert” “REMARK0” “s” sc pt1 “0” “” “” )
          );exit if
);exit defun
(defun search()
     (progn   (setq es (ssname s1 0))
                     (setq eg (entget es))
                     (setq sx (cadr (assoc 10 eg)))    ;INTSERT POINT X
              (setq sy  (caddr (assoc 10 eg)))  ;INTSERT POINT Y
              (setq sc (cdr (assoc 41 eg)))      ;SCALE FACTOR
              (setq ang1 (cdr (assoc 50 eg)))      ;block rotated radian angle
              (setq ang2 (/ (* ang1 180) pi))         ;;block rotation value
                     (setq pt1 (strcat (rtos sx 2 3) “,” (rtos sy 2 3)))
              (setq dx  (- (* (* 200 sc) (cos ang1))
             (* (* 100 sc) (sin ang1))
             dy  (+ (* (* 200 sc) (sin ang1))
             (* (* 100 sc) (cos ang1))
                     (setq pt2 (strcat (rtos (+ sx dx) 2 3)
                 (rtos (+ sy dy) 2 3)
              (setq scale (strcat “1:” (rtos (* sc 2) 2 0)));scale value
            );exit progn
        );exit if
);exit defun
  • 37 조회
    • 도구막대 이동시 미리보기가 안됩니다.
    2. 수야12 Lv.22
      2015-10-08T15:41:53+09:00답변 등록 답변 등록 일시 2015-10-08 3:41 pm
      약간의 주석을 달았습니다
