홈/ 질문/Q 169608
leoneplin
leoneplinLv.0
등록일: 2022-09-012022-09-01T09:17:09+09:00 2022-09-01T09:17:09+09:00카테고리: AutoCAD & CADian
단일선택리습을 다중선택으로 바꾸는 방법
(defun c:ahl (/ p1 p2 p3 p4 a10 a1 a2 s1 s2 lin pickpt linname lindata ang1)
(setq cosmode (getvar “OSMODE”))
(setvar “OSMODE” 0)
(setq lin (entsel “nPick a line: “)
pickpt (cadr lin)
linname (car lin)
lindata (entget linname)
p1 (cdr (assoc 10 lindata))
p2 (cdr (assoc 11 lindata))
p11 (cdr (assoc 10 lindata))
p12 (cdr (assoc 11 lindata))
(if ( (distance p11 pickpt) (distance pickpt p12))
(setq p13 p11
p11 p12
p12 p13
(setq ang (angle p1 p2)
ang1 (* (/ ang pi) 180)
a10 (* (/ 10.0 180) pi)
a1 (+ (- ang a10) pi)
a2 (+ (+ ang a10) pi)
(setq 1ang (angle p11 p12)
1ang1 (* (/ 1ang pi) 180)
1a10 (* (/ 10.0 180) pi)
1a1 (+ (- 1ang 1a10) pi)
1a2 (+ (+ 1ang 1a10) pi)
(if (= (getvar “USERR1”) 0.0)
(setvar “USERR1” 3.0)
(setq s1 (getvar “USERR1”))
(setq mess (strcat “nArrow Size = “))
(setq s2 (getreal mess))
(if (= s2 nil)
(setq s2 s1)
(setvar “USERR1” S2)
(setq p3 (polar p2 a1 s2)
p4 (polar p2 a2 s2)
(setq p13 (polar p12 1a1 s2)
p14 (polar p12 1a2 s2)
(command “SOLID” p2 p3 p4 p3 “”)
(command “SOLID” p12 p13 p14 p13 “”)
(setvar “OSMODE” cosmode)
선 양끝에 화살표를 그려주는 리습입니다만
한번에 1개씩만 선택이됩니다. 이걸 한번에 여러개 선택해서 바꾸고 싶은데 어떻게 수정해야하나요?
autocadlisp
  • 276 조회
    • cadplus_plot 사용방법 질문드립니다
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
      dhL Lv.12
      2022-10-03T19:20:06+09:00답변 등록 답변 등록 일시 2022-10-03 7:20 pm
      (setvar “OSMODE” 0)
      (setq ss (ssget ‘((0 . “LINE”))))
      (if (/= ss nil)
      (progn
      (if (= (getvar “USERR1”) 0.0) (setvar “USERR1” 3.0))
      (if (= s2 nil) (setq s2 s1) (setvar “USERR1” S2))
      (repeat (setq n (sslength ss))
      (setq ent (ssname ss (setq n (1- n))))
      (setq lindata (entget ent))
      (setq p1 (cdr (assoc 10 lindata)))
      (setq p2 (cdr (assoc 11 lindata)))
      (setq 1ang (angle p2 p1)
      p4 (polar p2 a2 s2)
      (setq p13 (polar p1 1a1 s2)
      p14 (polar p1 1a2 s2)
      (command “SOLID” p1 p13 p14 p13 “”)
