홈/ 질문/Q 102558
등록일: 2014-11-052014-11-05T13:25:50+09:00 2014-11-05T13:25:50+09:00카테고리: AutoCAD & CADian
뷰포트에서 사용하는 동결/해동 리습좀 부탁드립니다.
이건 모형에서 사용하는 동결 / 해동 리습입니다.
뷰포트에서 사용하는 동결 / 해동은 안될까요? 아이콘은 레이어도구막대에
해모양이랑 자물쇠중앙에 있는것.
(defun C:ddg  (/ ly ce)
  (setq ce (getvar “cmdecho”))
  (setvar “cmdecho” 0)
  (command “undo” “m”)
  (setq ly (getstring “nlayers to mode thaw only? (DEF:all) “))
  (if (or (= ly “Q”)(= ly “q”))
      (command “-layer” “f” “*” “u” “1*” “t” “1*” “”)
      (if (or (= ly “W”)(= ly “w”))
          (command “-layer” “f” “*” “u” “2*” “t” “2*” “”)
          (if (or (= ly “E”)(= ly “e”))
              (command “-layer” “f” “*” “u” “3*” “t” “3*” “”)
              (if (or (= ly “R”)(= ly “r”))
                  (command “-layer” “f” “*” “u” “4*” “t” “4*” “”)
                  (if (or (= ly “T”)(= ly “t”))
                      (command “-layer” “f” “*” “u” “5*” “t” “5*” “”)
                      (if (or (= ly “Y”)(= ly “y”))
                          (command “-layer” “f” “*” “u” “6*” “t” “6*” “”)
                          (if (or (= ly “U”)(= ly “u”))
                              (command “-layer” “f” “*” “u” “7*” “t” “7*” “”)
                              (if (or (= ly “I”)(= ly “i”))
                                  (command “-layer” “f” “*” “u” “8*” “t” “8*” “”)
                                  (if (or (= ly “O”)(= ly “o”))
                                      (command “-layer” “f” “*” “u” “9*” “t” “9*” “”)
                                      (if (or (= ly “P”)(= ly “p”))
                                          (command “-layer” “f” “*” “u” “0*” “t” “0*” “”)
                                          (if (= ly “”)
                                              (command “-layer” “u” “*” “t” “*” “”)
                                              (command “-layer” “f” “*” “u” ly “t” ly “”)
  (setvar “cmdecho” ce)
(defun c:DG()
   (command “layfrz”))
(defun c:fc()
   (prompt “n< 중심선그리기-직선 >”)
   (command “osnap” “”)
   (setq w-1 (entsel “n처음선을 찍으시오.. :”))
   (setq w1 (car w-1)) (command (redraw w1 3))
   (setq w-2 (entsel “n다음선을 찍으시오. :”))
   (setq w2 (car w-2)) (command (redraw w1 4))
   (setq wna1 (entget w1) xx (assoc 10 wna1)  w1p1 (cdr xx)
                          xx (assoc 11 wna1)  w1p2 (cdr xx)
         wna2 (entget w2) xx (assoc 10 wna2)  w2p1 (cdr xx)
                          xx (assoc 11 wna2)  w2p2 (cdr xx))
   (setq ang1 (angle w1p1 w1p2) d1 (distance w1p1 w1p2)
         w1p3 (polar w1p1 (+ ang1 (/ pi 2)) d1)
         w1p4 (inters w1p1 w1p3 w2p1 w2p2 nil)
           d1 (distance w1p1 w1p4) ang2 (angle w1p1 w1p4)
         l1p1 (polar w1p1 ang2 (/ d1 2)) l1p2 (polar w1p2 ang2 (/ d1 2)))
   (command “line” l1p1 l1p2 “”)
   (st_os “end,mid,cen,int,per”)
   (setvar “cmdecho” 1)
  • 23 조회
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
    • 오토캐드 호그리기 질문
