홈/ 질문/Q 173217
승현0125
승현0125Lv.0
등록일: 2022-10-082022-10-08T19:11:04+09:00 2022-10-08T19:11:04+09:00카테고리: AutoCAD & CADian
리습 공차오류 질문 합니다.
2015오토 캐드 사용 중입니다.
명령어 입력하면 streamp nil 오류가 나옵니다.
  • 156 조회
    2. 승현0125 Lv.0
      2022-10-08T19:19:42+09:00답변 등록 답변 등록 일시 2022-10-08 7:19 pm
      ; 공차 데이터 화일 쓰기 및 읽기
      (defun @Hec-data-setting(/ @Hec-data-first-list @Hec-data-read @Hec-data-while-list)
      (setq @Hec-data-file “c:\Dim-Tol.dat”)
      ;;공차값 새로 쓰기 ———————————–
      (if (not (findfile @Hec-data-file))
      (progn
      (setq @Hec-data-first-list (list ;”HCad 치수 공자 적용 리습의 환경 화일 입니다. 임의 변경 하지 마세요 !!!”
      “0.03” “0.01” “0.05” “0.02” “0.06” “0.03” “0.08” “0.05” “0.1” “0.05” “0.3” “0.1”
      “0.03” “0.05” “0.1” “0.5”
      “0.025” “0.05” “0.1” “0.5”
      “0.01” “0.03” “0.02” “0.05” “0.03” “0.06” “0.05” “0.08” “0.1” “0.05” “0.1” “0.3”
      “0.5” “0.8” “0.8” “0” “0” “Romans”))
      (setq @Hec-data-write (open @Hec-data-file “w”))
      (foreach x @Hec-data-first-list (write-line x @Hec-data-write))
      (close @Hec-data-write));progn
      );if
      ;;공차값 읽어오기 ————————————
      (setq @Hec-data-second-list ‘())
      (setq @Hec-data-read (open @Hec-data-file “r”))
      (setq @Hec-data-while-list (read-line @Hec-data-read))
      (while @Hec-data-while-list
      (setq @Hec-data-second-list (append @Hec-data-second-list (list @Hec-data-while-list)))
      );while
      (close @Hec-data-read)
      (setq @Hec-font (nth 41 @Hec-data-second-list))
      ;; @Hec-data-second-list 에 목록 저장
      ;; 공차 HISTORY 쓰기 및 읽기
      (defun @Hec-History-setting(/ @Hec-History-data-list @Hec-History-data-write @Hec-History-data-read
      @Hec-History-data-while-list )
      (setq @Hec-History-data-file “c:\Dim-Tol-History.dat”)
      (if (not (findfile @Hec-History-data-file))
      (progn
      (setq @Hec-History-data-list (list “+0.05” “+0.02” “2”))
      (setq @Hec-History-data-write (open @Hec-History-data-file “w”))
      (foreach x @Hec-History-data-list (write-line x @Hec-History-data-write))
      (close @Hec-History-data-write));progn
      );if
      (setq @Hec-History-data-second-list ‘())
      (setq @Hec-History-data-read (open @Hec-History-data-file “r”))
      (setq @Hec-History-data-while-list (read-line @Hec-History-data-read))
      (while @Hec-History-data-while-list
      (setq @Hec-History-data-second-list (append @Hec-History-data-second-list (list @Hec-History-data-while-list)))
      );while
      (close @Hec-History-data-read)
      ;; @Hec-History-data-second-list 에 목록 저장
      ;; Ok 시 최근 공차 쓰기
      (defun @Hec-History-Writing(/ @Ht-History-data-write @Ht-History-data-fourth @Ht-History-data-list @Ht-History-data-write)
      (if @Hec-History-data-thrid-list
      (setq @Hec-History-data-second-list @Hec-History-data-thrid-list))
      (setq @Ht-History-data-fourth (caddr @Hec-History-data-second-list))
      (setq @Ht-History-data-list (append @Ht-Tolence-Text-History (list @Ht-History-data-fourth)))
      (setq @Ht-History-data-write (open @Hec-History-data-file “w”))
      (foreach x @Ht-History-data-list (write-line x @Ht-History-data-write))
      (close @Ht-History-data-write)
      • 수야12 Lv.22
        2022-10-10T14:19:54+09:00에게 댓글을 달았습니다. 답변 등록 일시 2022-10-10 2:19 pm
        왜 그런지 모르겠지만 “c:\폴더추가\Dim-Tol-History.dat” 이런식으로 폴더를 추가 하면 작동을 합니다 그리고 이렇게 게시글로만 올리시면 복붙과정에서 정상적인 문자가 비정상적인 문자로 변해버려서
        테스트 하기 힘들어집니다 제 컴퓨터에서는 쌍따옴표가 쌍따옴표로 인식인 안되는군요
        • 승현0125 Lv.0
          2022-10-10T18:55:39+09:00에게 댓글을 달았습니다. 답변 등록 일시 2022-10-10 6:55 pm
          알려주신 방법으로 한번 해보시겠습니다 답변 너무 감사드립니다
          정말 너무 감사드립니다
      • GoCAD Master
        2022-10-10T20:52:14+09:00에게 댓글을 달았습니다. 답변 등록 일시 2022-10-10 8:52 pm
        (defun “@”Hec-data-setting(/ “@”Hec-data-first-list “@”Hec-data-read @Hec-data-while-list)
        “@”문자 값이 사용자 아이디 테그에 걸리는 듯 합니다.
        관련 내용 확인 해보겠습니다.
