홈/ 질문/Q 108663
등록일: 2017-07-192017-07-19T20:21:50+09:00 2017-07-19T20:21:50+09:00카테고리: AutoCAD & CADian
리습 실행 후 레이어 되돌리기
;센타선그리기
(defun C:CE (/ olderr clay sblip scmde e cen rad d ts xx)
   (princ “*** Circle ot Arc Center Line drawingn”)
   (prompt “n*** Edit by Myeong Seon ENG.”)
   (setq os (getvar “osmode”))
   (setq la (getvar “clayer”))
   (setq sblip (getvar “BLIPMODE”)) (setq cla (getvar “clayer”))
   (setq scmde (getvar “CMDECHO”))(setvar “CMDECHO” 0) (setvar “osmode” 0)
   (setq e nil xx “Yes”)(setq ts (tblsearch “LAYER” “C”))
   (if (null ts)(prompt “n* Creating new layer – C”)(progn
   (if (= (logand 1 (cdr (assoc 70 ts))) 1)(progn
    (prompt “n* Layer CENTER is frozen. “)(initget  “Yes No”)
    (setq xx (getkword “nProceed (Y/N) <No>: “))
      (if (= xx “Yes”)(command “LAYER” “T” “C” “”))))))
      (if (= xx “Yes”)(progn (while (null e)
    (setq e (entsel “n* Select arc or circle: “))
      (if e (progn (setq e (car e))(if (and
             (/= (cdr (assoc 0 (entget e))) “ARC”)
             (/= (cdr (assoc 0 (entget e))) “CIRCLE”))
           (progn (prompt “n* Entity is a “)
         (princ (cdr (assoc 0 (entget e)))) (setq e nil))))))
       (setq cen (cdr (assoc 10 (entget e))))
       (setq rad (cdr (assoc 40 (entget e))))
       (prompt “n* Radius is “)(princ (rtos rad))
       (initget 7 “Length”)
       (setq d (getdist “nLength/<Extension>: “))
       (if (= d “Length”)(progn (initget 7)
    (setq d (getdist cen “nLength: “)))
    (setq d (+ rad d)))(setvar “BLIPMODE” 0)(command “LAYER” “M” “C” “”)
       (command “LINE” (list (car cen) (- (cadr cen) d))
               (list (car cen) (+ (cadr cen) d)) “” )
       (command “LINE” (list (- (car cen) d) (cadr cen))
               (list (+ (car cen) d) (cadr cen)) “” )))
   (setvar “BLIPMODE” sblip) (setvar “CMDECHO” scmde) (setvar “osmode” osm) (setvar “clayer” la)
    (princ))
제목 그대로 리습 시작할때 레이어가  w 였다면 실행후 w 로 끝나지 않고 지금은 c 로끝이나네요 계속…
  • 27 조회
    • 도구막대 이동시 미리보기가 안됩니다.
      2017-07-21T00:22:23+09:00답변 등록 답변 등록 일시 2017-07-21 12:22 am
      감사합니다 ㅠㅠ
    3. 우기로기 Lv.0
      2017-07-20T12:17:46+09:00답변 등록 답변 등록 일시 2017-07-20 12:17 pm
      (setvar “osmode” os) 로 바꾸세요
