홈/ 질문/Q 187967
후추야사랑해
후추야사랑해Lv.0
등록일: 2023-10-312023-10-31T16:18:45+09:00 2023-10-31T16:18:45+09:00카테고리: AutoCAD & CADian
중량 리습 수정 부탁드립니다. ㅠㅠ
여태 잘 사용해오던 리습인데 오토캐드2016에서 2023으로  버전 업그레이드 이후에 문제가 생긴거 같아요.
폴리곤 선택시 원래는 정확하게 인식 되었고 크기가 작아도 선택 되었었는데
지금은 사진처럼 정확하게 인식도 안되고 작은 도형은 잡히지도 않네요 혹시 수정 가능하신 분들이 있으실까요?
(defun 객체테두리표시 (#aa / #a #b)
(vla-getboundingbox #aa ‘#a ‘#b)
(setq #a(vlax-safearray->list #a))
(setq #b(vlax-safearray->list #b))
(grvecs (list
-5 (list (car #a)(cadr #a))(list (car #b)(cadr #a))
-5 (list (car #b)(cadr #a))(list (car #b)(cadr #b))
-5 (list (car #b)(cadr #b))(list (car #a)(cadr #b))
-5 (list (car #a)(cadr #b))(list (car #a)(cadr #a))
);;list
);;grvecs
);;defun
(defun 면적체적중량표시 (/ #ap #ad #ut #as #os #count #index #a #b #c #d #e #f #g #h #i)
(vl-load-com)
(setq #ap(vlax-get-acad-object))
(setq #ad(vla-get-activedocument #ap))
(setq #ut(vla-get-utility #ad))
(setq #as
(if (>(vla-get-activespace #ad)0)
(vla-get-modelspace #ad)
(vla-get-paperspace #ad)
);;if
);;setq
(setq #os(vlax-variant-value(vla-getvariable #ad “osmode”)))
(vla-setvariable #ad “cmdecho” 0)
(vla-setvariable #ad “osmode” 0)
(setq #count (vla-get-count #as))
(while (not(vl-catch-all-error-p(setq #a(vl-catch-all-apply ‘vla-getpoint (list #ut nil “n≫≫≫Pick internal point:”)))))
(if(not(vl-catch-all-error-p(vl-catch-all-apply ‘vl-cmdf
(list
“boundary”
“a”
“o”
“r”
(vlax-safearray->list(vlax-variant-value #a))
(progn
(if (and
(> (vla-get-count #as) #count)
(eq “AcDbRegion” (vla-get-objectname(vla-item #as(1-(vla-get-count #as)))))
);;and
(progn
(setq #index 1)
(repeat (- (vla-get-count #as) #count)
(setq #e(vla-item #as (- (vla-get-count #as) #index)))
(setq #b(vlax-variant-value(vla-get-centroid #e)))
(setq #c(vlax-make-safearray vlax-vbdouble ‘(0 . 2)))
(vlax-safearray-fill #c (list
(vlax-safearray-get-element #b 0)
(vlax-safearray-get-element #b 1)
0.0
);;list
);;vlax-
(setq #d(cons(vla-get-area #e)#d))
(setq #i(cons #e #i))
(setq #index(1+ #index))
);;repeat
(mapcar ‘객체테두리표시 #i)
(mapcar ‘vla-delete #i)
(setq #i nil)
(vlax-release-object #e)
(setq #d(abs(apply ‘- #d)))
(initget 0 “A M B S SS”)(setq #h(getkword “n≫≫≫Meterial [Aluminum,Mc-nylon,Brass,Steel,Sus304]?:”))
(setq #g
(cond
((eq #h “A”)'(“Aluminum” 2.7))
((eq #h “M”)'(“Mc-nylon” 1.17))
((eq #h “B”)'(“Brass” 8.65))
((eq #h “S”)'(“Steel” 7.85))
((eq #h “SS”)'(“Sus304” 7.9))
(t ‘(“Steel” 7.85))
);;cond
);;setq
(vla-addmtext #as #c 0.0 (strcat “Area=” (rtos #d 2 2) “㎟” (chr 92) “P”
“Thickness=” (rtos(setq #f(getreal “n≫≫≫Thickness?<㎜>:”))2 2) “㎜” (chr 92) “P”
“Cubic=” (rtos(* #d #f)2 2) “㎣” (chr 92) “P”
;”Weight={\C1;” (rtos(/(* #d #f (cadr #g))1000000)2 2) “㎏}” (chr 92) “P”
“Weight={\C1;” (rtos(/(* #d #f (cadr #g))1000000)2 2) (chr 92) “P”
“Material={\C5;” (car #g) “}”
);;strcat
);;vla-
(setq #count(vla-get-count #as))
);;progn
(progn
(princ “nNot internal point.≪≪≪”)
);;progn
);;if
);;progn
);;if
(setq #d nil)
);;while
(vla-setvariable #ad “cmdecho” 1)
(vla-setvariable #ad “osmode” #os)
(mapcar ‘vlax-release-object (list #as #ut #ad #ap))
(princ “n「Designed by nonno」”)
);;defun
(defun c:ww ()(면적체적중량표시))
;;사용방법
;;선택집합의 (제일 큰닫힌객체 빼기 나머지 닫힌객체들) 을 연산하여
;;면적,체적,두께,중량을 엠텍스트로 그래픽에 씁니다.
lisp
  • 231 조회
      2023-11-01T09:30:17+09:00답변 등록 답변 등록 일시 2023-11-01 9:30 am
      리습 문제는 아닌듯 한데요……..
      캐드 종류에따라서…
      리습 컨트럴c/v로 올리면 역슬레쉬 기호 등 깨줄수 있어요……
      윗글 복사 하니 제 컴에선
      ((eq #h “SS”)'(“Sus304″ 7.9)) 이구간 Sus304 뒤에 따옴표 오류 나네요
      • 후추야사랑해 Lv.0
        2023-11-01T16:45:56+09:00에게 댓글을 달았습니다. 답변 등록 일시 2023-11-01 4:45 pm
        답변 감사드립니다 ㅠㅠ
