캐드에서 로드 시키고 Cx라고 치면 이런 메세지가 나옴니다
제가 리습관해 잘모르거든요. 그전에 잘썼는데… 답변부탁드립니다
Command: CX chprop
Select objects:
Command: CX Unknown command “CX”. Press F1 for help.
Command: c Unknown command “C”. Press F1 for help.
Command: bylayer Unknown command “BYLAYER”. Press F1 for help.
Command: lt Unknown command “LT”. Press F1 for help.
Command: chprop
Select objects:
Command: chprop
Select objects:
Command: chprop
Select objects:
Command: color
Enter default object color
Command: linetype
Current line type: “ByLayer”
Enter an option [?/Create/Load/Set]: s
Specify linetype name or [?]
Command: nil
리습 프로그램을 올려봐요
리습을 APP LOAD 하셨는지.. 하ㅕㅅ다면… 리습이 잘못된거 가튼데염…
