홈/ 질문/Q 32242
등록일: 2002-07-312002-07-31T11:35:30+09:00 2002-07-31T11:35:30+09:00카테고리: AutoCAD & CADian
Cx가 안돼요~~
캐드에서 로드 시키고 Cx라고 치면 이런 메세지가 나옴니다
제가 리습관해 잘모르거든요. 그전에 잘썼는데… 답변부탁드립니다
Command: CX chprop
Select objects:
Command: CX Unknown command “CX”. Press F1 for help.
Command: c Unknown command “C”. Press F1 for help.
Command: bylayer Unknown command “BYLAYER”. Press F1 for help.
Command: lt Unknown command “LT”. Press F1 for help.
Command: chprop
Select objects:
Command: chprop
Select objects:
Command: chprop
Select objects:
Command: color
Enter default object color : bylayer
Command: linetype
Current line type: “ByLayer”
Enter an option [?/Create/Load/Set]: s
Specify linetype name or [?] : bylayer
Command: nil
  • 38 조회
      2002-07-31T13:30:47+09:00답변 등록 답변 등록 일시 2002-07-31 1:30 pm
      리습을 APP LOAD 하셨는지.. 하ㅕㅅ다면… 리습이 잘못된거 가튼데염…
    3. 캐드플러스 Lv.18
      2002-07-31T12:19:33+09:00답변 등록 답변 등록 일시 2002-07-31 12:19 pm
      리습 프로그램을 올려봐요
